Integrate cloud files into the operating system with OX Drive
Storage space in OX Drive is included in Standard and Premium plans.
With the OX Drive application, you can integrate and synchronize your cloud files with the native file system of Windows, macOS, iOS, and Android. Simply follow this guide. Alternatively, and especially relevant for Linux users, you can also use the WebDAV protocol for this purpose. To do so, follow either the guide WebDAV for Linux or WebDAV for Windows.
Download links for OX Drive
The OX Drive client is currently available for Windows, macOS, Android, and iOS and can be conveniently installed via the mailbox webmail interface. Alternatively, you can download and install the software directly from the following links:
| Platform | Download link |
| macOS | Download from Mac App Store |
| iOS (iPhone/iPad) | Download from iOS App Store |
| Android | Download from Google Play Store |
| Android without Google Services | Download via Aurora Store (F-Droid required) |
Download and install OX Drive
To download the correct Drive client, follow these steps:
- In mailbox Office, click the gear icon in the main menu (upper right corner).
- Click Connect your device.
Option Connect your device in the main menu - Select the relevant platform from the list.
Selecting the device type or operating system - Select OX Drive.
- Follow the installation instructions displayed for your device.
Login credentials for OX Drive
The username corresponds to your mailbox email address. The specified ID must not be used as the username during the setup process.
If you have enabled two-factor authentication (2FA), an application password must be used for the application. If 2FA is not enabled, this step is optional and the regular mailbox password can be used.
The login credentials are the same for all operating systems:
| Setting | Value |
| Server URL | https://app.mailbox.org |
| Username | The email address you use to sign in at login.mailbox.org. |
| Password | The password you use to sign in at login.mailbox.org. |
Install OX Drive on Microsoft Windows
Option Connect your device in the main menu - Select Windows PC as your operating system.
Select Windows PC - Select OX Drive.
Select the Windows option - Click the Download button to start the OX Drive installer download.
Select OX Drive - Run the downloaded installer and follow the on-screen instructions.
- If prompted by Windows, confirm the installation by granting permission.
Once the installation is complete, you can set up OX Drive.
Configure OX Drive on Microsoft Windows
- In the setup wizard, enter your mailbox login details (primary address and password).
Once you have successfully logged in, the OX Drive welcome screen will appear.
- Check your folder settings, if needed. Here you can specify local folders and folders to be synchronised. You can usually keep the default settings.
Installation notes for Android, macOS, and iOS
To install OX Drive on Android, macOS, and iOS, follow the same steps described in the instructions above. Please note the following guidelines.
Android
- Make sure to install the OX Drive client only from trusted sources such as the Google Play Store or the Aurora Store (via F-Droid).
- If you use a device without Google services, you first need to install F-Droid to get the Aurora Store through it.
- Ensure that no background processes or battery-saving modes interfere with synchronisation.
macOS
- The OX Drive client can be downloaded and installed directly from the Mac App Store.
- After installation, you need to allow access to local folders and possibly log in at
login.mailbox.org. - If macOS blocks the app from running, you may need to authorise it in System Preferences > Security & Privacy.
iOS (iPhone/iPad)
- Requirements: Safari browser is installed and Apple File Manager is activated.
- Use the iOS App Store to download the app.
- After the first start, you will be prompted to sign in with your mailbox email address and password.
- Check under Settings > OX Drive that file access and background app refresh are enabled to ensure proper synchronisation.
