If you find yourself in need of advice around the mailbox.org Office software, have a look at our Help Section.
Make sure you are logged on to mailbox.org, then click on the menu icon in the upper-right corner of the page and select Help. A new window will open. There, you will find comprehensive information and guidance concerning the various mailbox.org office modules available.
