Using e-mails with a custom domain FAQ
This article answers some frequently asked questions (FAQ) about using custom domains in connection with mailbox.
General advice about using your own domains with mailbox
Please note that using your own domain requires technical knowledge, especially when it comes to DNS settings and domain registration. Our Knowledge Base contains detailed instructions on this topic.
If you need help setting up your own domain, the following article will help you: Use email addresses with your own domain.
If you have any questions about configuration or changing your provider, our user forum is also available to you: mailbox User Forum
I don’t have my own domain. Can I register a domain via mailbox?
No, because mailbox is meant to be used anonymously. For a domain registration, however, we would need your address data. Also, mailbox works as a prepaid system. If we were to register domains, the risk would be too high that we might have to delete them at some point, which would cause complications.
I don’t know what "DNS" is. What should I change where and how?
Using your own domain requires a certain level of technical understanding of how domains work and what the Domain Name System (DNS) is. This article in our Knowledge Base will help you further. If you have any further questions, please contact the support team of your provider who manages your domain.
What should I do if I no longer want to run my own domain via mailbox?
You can change this at any time. To do so, enter the details of the new provider in your domain’s MX records and delete the aliases from your mailbox account.
Can I use catch-all addresses with my own domain at mailbox?
Yes, this is possible. Details can be found in the separate article on Own domain and catch-all addresses.
Is the number of email addresses from external domains limited?
Yes. The maximum number of these aliases allowed depends on your chosen plan. You can find details in our price list. Here is an overview:
  • Premium plan: 250 aliases with custom domain
  • Standard plan: 50 aliases with custom domain
  • Light plan: Aliases with custom domain only in family accounts
Aliases for the user names postmaster@, abuse@, hostmaster@, and webmaster@ are not counted and can be created freely. Please create the previously mentioned aliases before you reach the maximum possible number of aliases.
