The mailbox Help Section
If you find yourself in need of advice around the mailbox-Office, then have a look at our Help Section.
Make sure you are logged-in to mailbox, then click on the menu icon in the upper-right corner of the page and select Help. Then, a new window will open. There, you will find comprehensive information and guidance concerning the various mailbox-Office features available.
Figure 1: How to open the Help Section.
