Answers for companies
CalDAV - CardDAV for Outlook - CalDav Synchronizer
Important after setup
Once you have enabled two-factor authentication, external applications such as Outlook, Thunderbird, DAVx⁵, or mobile calendar and contact apps can no longer access mailbox using your regular password.
To do so, you need to create an application password. Without enabled two-factor authentication (2FA), the use of application passwords is optional.
Outlook: CalDAV Synchronizer
In addition to ActiveSync, you can also use the free Outlook plug-in CalDAV Synchronizer to connect Outlook with mailbox.
You can download it here: https://caldavsynchronizer.org/de/download/
After installation, you will find a new tab in Outlook called “CalDAV Synchronizer”.
From there, select “Synchronization Profiles” to create the required profiles for calendars, task lists, and address books.
Once the menu opens, click the plus icon in the upper left corner to add a new profile.
From the list of available providers, select mailbox and confirm by clicking “OK.”
The mailbox configuration is already included as a preset option in CalDAV Synchronizer.
Adding resources
  1. Enter your primary mailbox address as the username.
  2. Enter your password (or an application password, if applicable).
  3. Click “Load IMAP/POP3 account settings” to automatically detect basic connection parameters.
Then, select “Search for resources and assign Outlook folders.”
This allows you to link the mailbox resources (calendars, contacts, and tasks) to specific folders in Outlook.
For each tab — Calendars, Address Books, and Tasks — go through the following steps:
  1. Click the icon with three dots next to the resource entry.
  2. In the dialog window, assign the resource to an appropriate Outlook folder or create a new one.
  3. Check your configuration and confirm with “OK.”
Summary of configuration steps
  • Installation: Download and install CalDAV Synchronizer from the official website.
  • Profile creation: Open Outlook → CalDAV Synchronizer tabSynchronization ProfilesAdd new profile.
  • Account connection: Choose mailbox from the predefined list and enter your login credentials.
  • Resource mapping: Assign each mailbox resource (calendar, contacts, tasks) to the corresponding Outlook folder.
  • Synchronization: Save your settings and start synchronization; all data will be kept up to date automatically.
Once the setup is complete, Outlook will synchronize your mailbox calendars, contacts, and tasks securely via CalDAV and CardDAV.
